The number of active links has fallen below the minimum required for the LAG to remain up.
Check to make sure links are active via show port sharing command
Warning
The number of active links for LAG %port% with %totalMembers% member ports has fallen below the minimum %threshold% active links required for the LAG to remain up.
| Name | Type |
| port | String |
| threshold | uInt8 |
| totalMembers | uInt8 |
